1 - 16 of 16 Posts
"How To" change air filter 2.4 JTD 10V 150
I recently noticed my JTD starting to get a little smoky. The air filter was due a renewal so I decided to change it. I’ve learnt a lot from this forum so decided to put something back and do a quick How to. This is my first attempt so be gentle.:)
It’s an easy DIY job and I hope it helps others out.
Firstly I removed the negative lead from the battery. I decided to do an ECU reset whilst I was at it and also it’s always good practice to do so. You will need your radio code after disconnecting.
You can just make out the air filter housing deep in the bowels of the engine bay.
Remove the plastic relay cover.
Remove the U shaped hose and cover the hose to the turbo to prevent anything falling in. I’d previously replaced the original clips with Jubilee clips to make things easier.
Pop out the two relays which will allow you better access to the relay bracket screws.
Unscrew the protective caps if fitted and remove the nuts (10mm AF). Push the relay bracket out of the way.
Unplug the MAF.
Remove the screws in the lid of the air filter housing.
Remove the lid.
Remove the filter.
Old and new together.
Replace the filter. I always put a dab of grease on the screw heads to stop them corroding.
The rest is just the reverse of the above.
If, like me, you’re very anal then you can give the engine bay a good clean when you’ve finished.
Good Luck.
Top Job :thumbs: although that old air filter :vomit:
as your PM box is full
fishy-steve said:
Hi Chris,
Is my "How To" worthy of a place in your How To sticky thread?
Steve.
:lol: didn't realise I was the arbitrator of how good threads are ... but yes I think so :thumbs:
sorry but one thing is seriously mising from here ,but IMHO you have failed to mention when taken filter out ,is to clean out air box of any dust debris ,as if your gonna eat ya dinner off it , as any dislodged muck will no doubt be sucked up on to MAF sensor and give problems of smoking lack of power and usual culprits of MAF contaminated
any filter replacement should be followed by the above
How would "dust and debris" pass the new filter.:confused:
:rolleyes:when you take filter out debris dust etc drop down onto base inside new air filter mounting area and that will go through to maf and how may owners had a service and not long their maf plays up or they havent noticed drop in power
I'll be doing this soon!!
Car was supposed to of being serviced before I got it but doubt is setting in that it had any more than a stamp in the book!!
1 - 16 of 16 Posts
