1 - 10 of 10 Posts
· Registered
Hi guys !
Manual says 4,4 lt. when you change the filter and 5 lt. all the system when it is empty.
I did my oil change yesterday ( with 1.200 miles and 6 months oil was like new ! ) and I only can fill 4.100 lt. in ! :confused:
The last time the same. How much do you use to fill ?
( I fill it one day with 4 lt. and the follow day check how much it needs and I refilled only 100 cc. just at the top of the dipstick )
· Registered
Depends on how well you drain it. Ensure the car is on a level surface, or the plug hole is lower, and allow it to drain for longer and with hotter oil.
· Registered
Maybe on the dark side of the moon you need this viscosity because of excessive heat???
Well, I've been having to put 1 litre of oil to top up the oil tank after each 1000kms - I reckon it's consumed 26 litres of oil in a year so far...is this normal? I'm not a hoon and I don't drive like a nutter, it's mostly city and the occasional freeway driving, I redline it now and then but certainly not all the time.
· Registered
1 litre pre 1000km's is not unheard of :rolleyes: I heard of a 147 1.6 only doing less than 500km's per litre :eek: :eek: :eek: :(
robinsong said:
Ive done 8000 miles is 6 months and only used a litre of oil in my 2.0 litres twin spark.
Madryoch, 26 litres must keep the cobb webs out the wallet :eek:
It's a lease vehicle thank God. Since this is my first Alfa (used to drive a Honda Integra Type R) I wanted to make sure it was leased so I could get a feel for the maintenance requirements. ;)
1 - 10 of 10 Posts
