Hi guys,
sorry, haven't been able to find the answer to this in all my searching;
How loud should the click of an EGR be on a 1.9 JTDm be? My g/f's 147 is giving some grief, intermittently no power leaving junctions, but only when the engine is cold, after the last couple of cold nights. Once it's up to temp it seems fine. So I cleaned the EGR, it was full of gunk but it didn't seem stuck but then this is an intermittent problem.
Anyway, both before and after cleaning I can activate the EGR via Fiat ECU Scan, but the click is not very loud, barely audible really (with the engine off). Is that right or should I be hearing a solid loud click?
Thanks,
Chris
Thanks Dave!
M
what you can do is unbolt it but leave it plugged in then you can see it being operated
If you can use fiat ecu scan you can watch it operate it open and close without starting engine. did you follow guide to clean solenoid as well?. If not may be worth doing. Also check holes in intake are clear as well.
John
