S
How hard is it to fit a GTA intake pipe to a TwinSpark. Mine turned up today and wanna fit it for tonight but not sure how hard it is. Anyone know?
Cheers in advance!!!
Very easy
Did you get all this?
60677409-GTA intake
7663916-Pad
60630491-Spacer
12624101-Washer
15697604-Screw
It will work, but you'll have to use something to steady the pipe .. tie-wrap maybe.
Check out my greenserpent website .. under the Hints & Tips is a V6 intake pipe how-to .. same principals involved. The hard bit is getting the old resonator off the air-box and out of the inner wing.
Nope, just the GTA intake imm affraid. That ok?
You could get away with a few long tie tags but the metal structure you tie them round is very sharp. May cut through it eventually due to vibrations.
Hang on ... Smallville ... you've got a 147 .... 156 GTA pipe WON'T fit ... 147 has a panel type filter, 156 a round cylinder filter ...
Well spotted Gazza.
the new layout is taking time to get used to.
S
I think some people might be getting confused. Its just the pipe that comes from MAF I believe to the actual airbox. The actual panel filter will be the orginal :D
