idd. but it flexes too much, watch when you jack up the car...strutbraces do a great jobGood chassis (some parts made of chocolate), good steering feel - cracking drive.
Funny enough, if I jack up the rear of my SW using the proper jacking points the other side wheel also comes off the ground. That doesn't seem to indicate a flexible chassis! Could be the Eibach ARB?idd. but it flexes too much, watch when you jack up the car...strutbraces do a great job
to stiffen the lot !
Certainly can, no problems with opening doors when jacked up.If you jack the back up can you still open the doors properly?
On my 156 (Saloon) the body flex stopped the doors closing properly when it was jacked up.
That's a bit strong:-( Have you ever driven a Vauxhall (Opel) Vectradon't know if sitting on the opposite side of the vehicle disturbs your proper judjementbut the 156 is about the shittiest car on corners i've ever driven...
Maybe with that big diesel lump in the front of yours.don't know if sitting on the opposite side of the vehicle disturbs your proper judjementbut the 156 is about the shittiest car on corners i've ever driven...
Thats because you have the heavy diesel lump up front, and sportwagons didn't get sport suspension.don't know if sitting on the opposite side of the vehicle disturbs your proper judgementbut the 156 is about the shittiest car on corners i've ever driven...
Strut brace, and a set of coilovers would do for a start.allright then any ideas how to fix this without ruining the ride comfort too much?![]()
