1 - 10 of 10 Posts
Just wondered if to bleed the slave on the 147 you release the clip then pull the pipe out to the first notch then pump the pedal or is it a different method ? Does it need to be running or not?
Any advice would be great:thumbs:
Panda 4x4 TwinAir
Exactly like that, it doesn't need to be running
Panda 4x4 TwinAir
Not sure mate, only ever seen this type on my 147, others have had the typical
screw-in bleed nipple
Alfa Mito, 2010, 1.4NA, 6-speed
You have to pull the clutch pedal back up too .. doesn't spring back like the brake. Maddening if you are trying to do it on you own!
or use a pressurised bleed system
I could never get that clip to bleed it correctly. In the end I just used my finger over it to block it on every move pedal back using myself and my brother to pump the pedal.
Like the old skool way of bleeding brakes.
Actually made it easier than clipping in and out and was done far quicker.
I only managed it successfully using a pressure bleeding kit.
I did it alone, but only by pushing the feed pipe back in after every downward pedal stroke, then running around to pull up the pedal, then pulling the pipe out, then running back and pushing down the pedal, then ... well you get the picture! Luckily it didn't take too many goes. I was clearing the old fluid out after replacing with Castrol Performance so I'd all but emptied the reservoir.
Fitness vs price of an Ezibleed? ;)
I was getting the power steering fluid back in and bleeding that system with my brother.
Told him to get in the car to turn the wheel slowly from lock to lock.
The cheeky bugger got straight in the car and whacked the clutched down. As none of the ancillairies had been connected properly the clutch to slave just flew off covering the paint work with DOT4.
Almost had to lay the smack down on him for that.
Still never mind hey. All part of the fun and games.
Discussion Starter · #10 ·
I did it :D what I did was put a pipe on the nipple and into a container then topped the resovoir pulled the pipe back to the first point, then pushed and pulled the pedal and left it for 10 mins whilst doing other bits keeping the resovoir topped up and it gravity bled then pumped the pedal gently twice then pushed the pipe in and hey presto :thumbs:
1 - 10 of 10 Posts
