1 - 9 of 9 Posts
My front calliper is tarox 6 with a 315 disc,when the car stands alone it looks weird...Coz the front disc is much bigger than the rear,,,,Just wondering,how big of a disc does the stock callipers can take?
there are 2 rear disc sizes.
251mm [ upto approx sept 2001 ]
276mm from then on [ on most models ]
swapping 251's for 276's may not do anything for your car except improving the cosmetics
you would need calipers x 2, mounting brackets x 2, discs x2 & dust shields x 2
As its a 147 (Buit from 2001...) there is only 1 size and the size fitted matches the caliper, so there isnt a stock option for bigger rear stoppers.
You will need to be careful if you do alterations to the braking in this manner though, proper engineering of the hydraulics and custom pressure set up is required.
H
Changing the rear discs and calipers only to larger ones will affect the brake bias between front and rear.
No front wheel drive cars have big brakes..
thanks for info....
Ohh...i see.....So i guess the gta rear calliper and disc would fit....how big is the disc size for a standard gta be?:)
K
The 147 is a very small car to have very big rear brakes. It could quite possibly get by with drums on the back because the discs will do so little work. An adjustable brake balance control might be useful so that you can dial out any tendancy for the rears to lock up.
thanks for info....
Think they are the same across all models ... 276mm according to brakeparts.co.uk ...
C
thanks for info....
Its the same size as a normal 147, the only difference is the caliper is painted red.
1 - 9 of 9 Posts
