1 - 9 of 9 Posts
Went to drive TIa the other night and SHE wont start.
Deafness Disney help butt I hear a whirring coming from the area of thon black boax OSF.
Havnae had time tay check properly as I'm catching up oan Amazon Prime (BUT that's another Jackanory ) AND recycle boax is full of cardboard courtesy of Amazon.
So if my Engrish gets wurser BLAME Amazon lol and Outlander.
Has dayin the blake pipes done summit IE The pipes oer the tank and moi disconnecting the fuel line
NB Nay smell of petrol
Pomeo
Off tay hospital as faither in law's wife inn.
Pomeo
Pomeo
Pomeo
Pomie I would check the 'power line' to the fuel pump.
I've known of two owners (myself being one) where the wire has corroded
and burned out breaking the connection.
Hugs and all the best to your family,
MOOFasa
PS I find the drunker you get the better your English becomes!
Thanks Roar , Not had a chance to look at it yet. Where was your dodgy break?
Thanks fur yer guid wishes. they are awe fine noo Well considering their age. When I dsay fine that means they're noh in the hospital.
Whit alcohol is that so as I cun buy sum. Eye canne re read sum o mah posts. :rofl:
Pomeo
My mechanic fixed it so I'm not sure....
:rofl: :rofl: :rofl: Brilliant. I might ,jist might be heading that way soon BUTT not yet hopefully. Thanks for the tip. I think it's a nice weekend so will try then.
Had a real meatloaf moment the other night.
Took the 3 keys (Abit like the 3 bears too and eye wiz Goldilocks :lol:)
First the van , Turned over fair enough but not enough to fire up.
so moved to TIa. She should be fine
Secondly TIa turned over and over but widnae start. Then I heard the suspect whirring from the black box area.
So moved to the Vectra.
Strated nay bother. New battery did the trick AND buying wisely now as it does both van and Vectra and although they say it is recommended for the 166 I woodnae stick a 70Ah battery in 166. 100 Ah or nothing.
So drove the Vectra and goat the diesel sound fray a petrol Transpires its the VVT variators . So glad I never did the belt as they failed after it was scheduled to be done. So now 2 birds . IF only last year I had treaded that in for a Santa Fe and the Van for an all electric Golf. However that boat has sailed.
Returned and jumped the van from the Vectra with my 50 year old jump leads.
So 2 out of 3 aint bad but we need perfection. Driving the TI at night is therapeutic with the red lighting.
Pomeo
Discussion Starter · #6 ·
I had a quick butchers hook the day,. DOH Yup pure Simpson moment the other night.
The noise I heard, even tho I am deef , was the headlight motor adjusting. Now the battery is flat with trying the day.
Shirley its no just a flat battery. Will try to jump it tomorrow weather permitting or take oot the battery and charge it.
Its just that these 100Ah batteries seem to be getting heavier even although its the same weight.
Pomeo
Discussion Starter · #7 · (Edited)
Yup These cars just eat batteries. :cry:
:munch: :munch: :gobble: :gobble: :pacman: :pacman: :pacman: :curse:
Pomeo
Pomeo
Do you disconnect the neg terminal when not in use?
I do that with all my parked up fleet.
  • Like
Reactions: Pomeo
Discussion Starter · #9 ·
Million dollar ? that Roary.
Chris Rhea...Road to Hell an awe that.
Pomeo Disney open wie the Knack. Lacey Lucy And TIa do.
Also when you factor in forgetfulness and slight dementia....Cannae remember whiuh ones Are and Aren't
So now I am just gonna have to drive then more often and regularly.
Also when you factor in the roulette door lock Its no easy ewe ken:angel:
Pomeo
1 - 9 of 9 Posts
