1 - 2 of 2 Posts
I cant find or dont no were to top up the hoods fluid ? Is it the same pot as the brakes/clutch. Or power steering.? help😯
Open the cubby hole behind the seats, remove the lining and the reservoir is on the opposite side to the battery. 13mm spanner to remove the top. Check the level with the car on flat ground, hood down and clamshell shut. Easiest checked using the camera on your mobile. I top mine up with a large syringe and plastic tubing.
1 - 2 of 2 Posts
