1 - 9 of 9 Posts
Alfa 156 1.9 mjet 140hp 2004
Just wondering if I had a hole in the air intake hose (the one with three ends), could that be a cause of a MCSF?
I have looked at several other things but they are not the cause.
I believe that tube is called the snorkle. A leak after the air flow meter will cause your car to run poorly. If you don't know where the airflow meter is (MAF) it is on top of the air box and has a plug and wire connected to it. If the engine is recieving any un-metered air the cars map is going to call a fault and probably run poorly.
best is to plug it in to MES and read the fault codes.it might not be air intake related at all
  • Like
Reactions: dgmayhead
cool, that is what I was thinking....the error is wrong fuel pressure, but if the air quantity is not correct, actually if there is more/less air it can show the fuel error...
Am I right?
Am I right?
Not sure. I'd expect a code associated with MAF and MAP not fuel rail pressure if air was drawn in elsewhere. The car would presumably be down on power and under fueling.
Have you found a leak?
What does the car run like?
Am I right?
Have you a code that points to "wrong fuel pressure"? If so, what is it?
I'm not aware of a specific code for "wrong fuel pressure".
1 - 9 of 9 Posts
