Hi, I have a problem with the high beam adjustment on the Giulietta. I have halogen lamps.
When I try to adjust the high beam with the hex bolt 8mm it does not change the light position. I believe the 8mm bolt is out of position with the light regulation inside the lamp.
Have anybody had the same problem and do you know how to connect the bolt to the light regulation inside the lamp again?
