Just wondering is there any HID kit to fit the alfa romeo 156 facelift model?
Any recommendations?
Thanks in advance
Yes, exactly the same H7 kit as all the others...!
Get the shorter H7C to make sure they fit under the metal caps in the lights.
Then make sure you have headlight washers and self levelling suspension as it looks like there's new rules being phased in in may for the mot, that might make them a fail!
i wont be woried about the (MOT) or as we call it NCT here in ireland,
What i wanted to know which kit should i buy because i want to do dipped beams and high beams on it?
If you read the MOT wording carefully (NOT the incorrect info on the AA website) all it says is that IF you have Self-Levelling headlights/suspension and/or headlight washers, then those now need to work.
There will be no way of testing most self-levelling suspension anyway.
I wouldn't bother with the main beam.
If you insist, the mains use H1 bulbs.
