1 - 10 of 10 Posts
Hi
I seem to have a problem with the electicrics
the car turns over but will not start the battery is ok.
the car just cut out while driving it just before xmas and now wont start when u start the igniton the speedomiter goes up to 60mph even though the car is not moving please help
What car & what engine?
(obviously not a 157 as they don't exist!)
D
Is the injection/engine management light on/not on/goming on then going off?
Is the code light coming on then going off ?
Hi dave
the engine signal light is on on the dashboard when the ignition is on. when the car first stopped it stated system failure then stopped
What about the "Code" light?
Does the fuel pump run?
Has it got any Petrol in it...?
Does the engine sound like it is turning over faster than normal?
hi
Firstly what is the code light im a bit thick when it comes to that stuff.yes the engine does seem to run faster,there is oil and fuel in it and the fuel pump is running
The "Code" light is the one that says "Code" on it...!!
Unfortunately turning over faster than normal is pointing to a possible cambelt failure...
Hi Dave
I have checked the cam belt and that is fine the code light comes on and then goes out the only light that stays on once ignition is on is the engine symbol light on dash board
1 - 10 of 10 Posts
