1 - 16 of 16 Posts
hey this is my first post and i am pulling my hair out my 147 did'nt want to start this morning turned over but no firing now there's fuel in it altho the gauge says not (no fuel light tho) also noticed that i have no interior light the electric windows won't work nor the central locking the stereo wont work altho it does light up with cancheck on the display ...have i had a full electrical break down or is something as simple as a loose plug
please help im already late for work lol :cry:
no batterys fine turning over fine the window swithes light up but just dont work the windows all the dash is lit up ok too
ive just found a grey plug with a single black wire thats not connected to anything in the fuse box under the dash any ideas?
Take the complete fuse box out(everything unplugs)and dry it away from direct heat,the body computer(it is the unit plugged behind the fuse box)may have water in it,
If your are lucky enough,it may just be ok after drying.
done just wait and see now ..... will another one work if it is done for theres no coding or anything in there for imobaliser is there
Unless your sure there is enough fuel in the car I would try getting some in first.
I only say this because my 147 needle never went all the way down to the pin. Soon after I bought it I drove home whilst it was almost on zero, got home fine, parked up etc no problems, I just thought I'd fill it up on my way to work in the morning. It didn't start in the morning, and after I filled it up it did.
Discussion Starter #15
yea i put £50 in it yesterday which is why i was confused when it was showing empty then noticed no inside light checked other things then and some worked some didnt
OK, before you put the fuse box and body computer back in, find out where the moisture came from?
Dry it all out with a towel then have a look at the window-screen seal is it flush against the car?
If you can't find it via a visual check, try pouring little bits of water on the window down the drivers side, to see if it's leaking through?
1 - 16 of 16 Posts
