Right, Blaupunkt MP47 is ordered and on the way. Connects2 fascia adaptor arrived today, and steering controls adaptor is also on the way. So, a few questions.
The 'A' ISO connection (power block). I am looking at this in the installation instructions for the Kingston and trying to reconcile it to Tall Paul's excellent diagram of the factory fit GT stereo. I've attached a table to compare the 2-can anyone tell me what I need to do to reconcile the 2 setups? I've read some threads that suggest it may be necessary to muck about with the wiring (removing, reattaching,soldering etc), but I'm not sure I'm up to it-or even if it is necessary-is there an ISO adaptor solution I could use?
Also, the ISO block for the CD changer seems slightly different-on the factory fit model, there are 7 connections (C13-C19) while on the Kingston there are 8 (C13-C20). I presume there is a 'mistake' on Tall Paul's diagram as there is no 'Input R', only and 'Input L' whereas the diagram for the Kingston has both 'Line in L' and 'Line in R'
Can anyone recommend a paint solution for the Connects 2 fascia adaptor that will match the dash of the GT better than the unpainted version?
Can anyone recommend a way of putting a hole in the glove compartment for the USB cable? I will be attaching a memory stick that was ordered with the stereo.
Any suggestions/advice appreciated.
