1 - 9 of 9 Posts
hi,
I have just replaced the crank sensor since my car would not start when warm. Now it wont start at all. There seems to be no spark any suggestions please does it sound like the ecu has gone.
Couple of questions...
Did you get a genuine bosch one?
Did you retrieve the o-ring from the original sensor? If it's left in, it can cause problems.
Did it ever cut-out when it was warm? Another possibility might be the coolant temp sensor...
hi,
no it wasn't a bosch one
i did take the old O ring off and
it never cut out when it was warm just when i went to restart it after a few minutes or 1hr later.
I had someone round and they are suggesting an ecu repair so just trying to see if i could try anything else first
Had a Diagnosis check and its coming up with pin code 30 and pin code 33 any ideas, dont really trust what the bloke is saying
1 - 9 of 9 Posts
