Hello all, I apologise if the following question has been answered before.
I have been having electrical problems with my 147 (surprise, surprise) and they seem to be getting worse. It all began a few weeks ago when I went to start my car and the battery was dead. I jumped it and charged the battery again and it seemed fine for a week but then one day I went to start it and the battery was dead again! I thought my battery was finished so I bought a brand new one and hooked it up. All seemed fine again. It worked every day for a week or so but then I left it for a couple of days and again the battery drained. So now I knew it was an issue with the car I began to investigate. I tried a few easy fixes but they didn't work. I then read that I should clean the terminals as they can drain a battery. I cleaned the terminals and charged the battery and this time I really thought I'd cracked it. Everything was working fine. I left the car a few days to test it and to my joy it started!!
Then... a few days later the engine management light came on as well as something on the display (a key that says "code" underneath it). The car drove fine other than these warning lights. Then I went to switch off the engine and the high beams turned on!! Basically if I started the engine the lights went out and when I turned the engine off they came on! Eventually they went out when I turned the engine off for about the 10th time! I was now very worried that something drastic was wrong so I booked it in to a garage. Then the plot thickened as on the day it was due in the garage I went to start it and not only did it start fine there were no warning lights!! No engine management light, nothing. Everything was working! I cancelled my garage appointment and all week have been driving around without issue.
Finally today I went to go for a drive and the engine management light came back on. I was concerned so I drove straight home, I pulled up and turned off the ignition but, not only did the high beams come on, but the engine also stayed on!! I waited for at least 5 minutes and nothing happened. So I tried turning the key etc and still nothing happened. The engine just kept running! In the end I had to stall it just to get it to stop. I tested it again and the same thing is happening.
I am certain it is a major electrical fault and can't really afford to even have it looked at, let alone repaired. My question is: how likely is it that it could just be the ECU that needs to be reset? I know someone who can do that for me cheaply but obviously if it doesn't work I'll be out of pocket and still in the same situation. Any assistance would be greatly appreciated.
Cheers,
Ben
Cheers,
Ben
