· Registered
Hi, I write from Spain for that sorry for my English.
I need upgrade the brakes of my Alfa Sprint (front axel, output gearbox) and I do not find a cheap solution to be able to install big ventilate discs and big calipers (brembo or similar). Can you to help myself, someone to fact already this?
Thank you very much.
· Registered
thank you very much,
I've been looking but all options are for brakes outboard. Disc replacement with 33 are directly ... The mine has 6 holes.
I want to keep the brakes inboard order not to change the whell.
· Registered
I went for 264 mm Tarox F2000 ventilated discs with Brembo calipers from Alfa 75, Wilwood 4-pot calipers should be better..
hi mr Sprint. am building a tracksud currently running std calipers with the spacers in centre and i think mazda discs, and was wondering are the bells one-offs made to fit those discs to the sud outputs? or an off the shelf item? and do the 75 calipers fit staright on or need mods??
thanks in advance....
