New member looking for help, have changed cam belt no spider
TS 2000 (2000W) & lost balance belt timing marks, can any one
help with how to set the two balance shafts with crank sharft.
thanks
nick
The marks on the belt don't really mean much.
All you need to do is fit the belt so that the marks on the balance shaft gears point towards the top of the engine whilst Cylinder 1 is at TDC on the compression stroke.
As you know the engine slants forwards slightly, so the balance shafts will not be pointing vertical in relation to the car if they are set correctly.
