Hi all,
Hope there is a quick fix to this but my temperature guage doesn't move from it's resting point. The antifreeze/water level is fine and the heater works as normal!
Not sure if it's coincidence or not, but I got it back from Rusper Alfa on Tues eve after having a new metal brake pipe made along with new front flexis fitted. Could anything be disturbed? Is there a fuse/relay to check.
I believe the thermostat is on the top left of the engine as you look at it from the front but there is no wiring coming from this!
Any ideas would be great! Not having a lot of luck with my Alfas at the moment!
Cheers :thumbs:
Hi ya
Sounds like the sensor connection has been knocked off or the wire has been caught and cut!
What engine is your 75 TS or V6?
Might be a sensor fault but usually in my experience my play about first, to go dead usually means no signal.
I checked at lunch time and the spade connector had been knocked off. Re-connected and working fine again! Phew!
