I've asked the questions before - so sorry to go on but I'm ready to give up on it.
I took the car out for a good drive today to try and get a grip on what I thought the problem was. I've posted this up already but essentially I have what feels like a very bouncy front end. I've replaced the rear subframe and poly-bushed the lot, new Kyb standard shocks and the old springs, front has new wishbones, new Monroe shocks and Kyb springs. I've had it 4 wheel aligned. Been playing with tyres pressures but it doesn't seem to make much difference.
Fast smooth roads and its fine, as you'd expect, start going over undulations and the ride gets very unsettled, a few bumps and its bouncing around and bl00dy awful.
When I got back I decided to try just pushing each corner down to see how it felt. The front end can be moved slightly and it releases with no rebound, the back hardly moves, it feels almost solid, when I get some movement it transfers to the front. If I stand on the tread plate and jump up and down the front moves but the back doesn't, so I'm thinking that anything picked up at the rear is being transferred to the front. I've had the subframe components checked for the correct torque settings whilst having other work done at my local Indie.
I'm thinking that I've somehow put the subframe components back together incorrectly - is there a proven procedure to follow?
Any theories?
It was suggested that I get newer springs for the back but surely that will make matters worse?
Any theories?
