1 - 9 of 9 Posts
Is there any kind mechanic out there who can help with a strange knocking sounds I have from my 156 since I changed the lower/upper wishbones, car went into garage yesterday but they have no idea what the knocking is.
If so contact me on 07850 260817
I live in Long eaton , Notts area, but can travel.
Andy.
knocking can be tied rods ,tops wishbones tend to squeak,unless really shot ,lower arms can knock if badly warn and antiroll bar bushes
Hi changed all wishbones and droplinks, the knocking only appeared aftyer i did this job, disconnected the droplinks and its still there, so its nor ARB, I just have no idea what it is, my local garage checked it our yesterday and they drew a blank.
Only happens when i pull away in 1st and 2nd gear hard, it knocks and then when i lift off itgoes away.
At the ends of my patience with damn thing,
Hammo.
drive shaft could not be seated right ive seen similar problem on here regards a knocking after lower wishbones been done
Yeh Ive been thinking something with driveshafts, is this easy job to put right, or best left to garage.
Andy.
If you take it to a garage, don't take it back to the muppets you went to earlier .. a knocking driveshaft should be easy to spot.
When you did the lower arms, what end did you disconnect on the driveshaft .. or didn't you?
I never disconnected the driveshaft, but i did struggle for a complete day fitting the wishbone, so could have done some damage to the driveshaft i guess when refitting the lower wishbone.
What do you think Ive done to the driveshaft, its booked in at specailist Alfa garage on thursday, so hopefully they will fix it as Im going to Cornwall on saturday for my hols.
Hammo.
Rear bottom engine mount. I had the same problem. When you accelerate hard the worn mount cant handle engine moving anymore so it knocks on the driveshafts.
1 - 9 of 9 Posts
