1 - 9 of 9 Posts
Evening all,
A quick search on the forum yielded no results, so here we go: how does one remove the 4 air vents from the dashboard? Specifically, the 4 round front-facing ones.
If I recall from the 159, it takes two J-shaped pieces of wire/metal and a firm tug to pull them free. Is it the same for the MiTo, or is there a different trick to it? Any chance of breaking clips or needing replacement retaining springs/bits/etc?
Much appreciated!
I need some replacement from other cars. There was a benz A klasse retrofit. But they are hard to find. May be some mini cooper ones can fit also.
Funny you mention the A-Class, as those are the ones I’ll be fitting! Personally I prefer their look over the stock ones, which -to my eyes- look a little bland for what is otherwise a very nice place to be.
Still, I do need to get the old ones out first. So before I go out and wreck my new (to me anyway) car, anyone ever tried to remove them?
Just clamp a screwdriver (flat) inbetween the vent and the dashboard at the bottom of the vent and lever it upwards. During this movement pull it out. Quite easy.
Can you share some knowledge after fitting them, some dimensions, pictures. I only watched a video of fiting them.
Will report back once I actually get round to it. Those Thursday-night plans got changed once drinks got involved..
Any chance you can link that removal video? Couldn’t find any myself. Thanks!
Allright, so had an hour to spare tonight, turned out I needed only 5 minutes. Apologies in advance for the poor quality photo's. The sun sets ever earlier these days, and with time only being available after a days work I have to do this in the dark. As for the actual job:
Thanks to the tip from JnL, removing the original vents was dead easy. Simply place a flathead screwdriver underneath the vent between the outer ring and dashboard, apply mild pressure by twisting the handle and a firm pull will release the vent. You're now left with a hole in the dash and the insert in your hand. Location of the original insert is done by a guidance ridge on the insert and a matching cut-out in the dash, as shown in the pictures.
The A-class vents use a different method. Four retention clips would normally secure them in the dash, but this makes them a fraction too large to fit the MiTo. I recon, though I didn't measure the difference yet, that they're around 1-2 millimeters larger in diameter, if that.
So I'm now left with 2 new questions: how to fit the new vents in the dash, and then how to secure them (rattle-free). :read:
To be continued in the daylight...
YES! :smokin: Frantic Googling (for lack of daylight once you get back from the office...) has actually yielded a result.
This video shows you how to modify the A-class vents to suit the MiTo's dash. I'll definitely be giving this a try in the near future, but I didn't want to withhold my find from you guys. It's in Italian, but the pictures speak for themselves.
To each their own, but I personally much prefer the look of the A-class style vents over the regular ones. Can't wait to get this done! If anyone else does, please let me know how you got on.
1 - 9 of 9 Posts
