I have just bought a cheap diagnostics kit and received the following codes:
(I have an '03 156 JTS)
1. P0120 pedal position sensor a circuit malfunction
2. P1121 throttle position sensor circuit intermittent high voltage
3. P1121 throttle position sensor circuit intermittent low voltage
4. P1687 metering oil pump stepping motor circuit malfunction
5. P0505 idle control system malfunction
6. P1151 pending lack of HO2 S21 switch sensor indicates lean
Could anyone give me any info on these codes as i dont have a clue & obviously dont want to spend too much!
Thanks Ian
Thanks Ian
