Just drove of from home and check engine light comes on.... Plug in mes and error P1850 comes up. Clear it. And it keeps coming up, anyone had this issue.
The gearbox has microswitches to indicate which gear is selected. I think it may be a failure of one of these switches giving your problem. I didn't experience it myself but will have to research how it works before being of more help.
the error has stopped. i think theres a loose switch or with the bad weather water may have been causing connection issues, im hoping.
i read up that the sensor is under the gear lever which requires the heat shields to be removed.
I hope it was just water or dust.
sounds like a job to get to them. But usually the plugs are well sealed. Anyway, report at your next service and ask them to secure and spray with contact cleaner. Should probably still be under warranty?
out of warranty,seem intermittent, comes on, switch of and when it feels like it. it will come on, will check it up when im in durban, need to go under the car
