· Registered
Would appreciate some advice on how to remove and fit part 2 on the attached picture...
· Registered
Discussion Starter · #2 ·
Just had this done and you really need a body shop to do it.
Apparently whilst part of it clips in, the rest is riveted and bonded! Took my friendly body shop a little under 90 minutes to do the pair.
· Registered
What was the problem with the originals?
Small patch had started to bubble and then the bubble burst to reveal white underneath, which when 'cleaned' think it was just a mark got a bit bigger.
Probably was only a centimetre in length and half a centimetre wide, but really annoyed me!
The other side had a few bumps right at the end of the trim by the rear window so did that at the same time.
Of course Alfa wanted £150+ each bit of trim which would have meant living with it, but I was 'lucky' enough to get both for £100 and then £30 to fit...
