Good Evening All!!
This is my first post - and sorry it has to be a HELP me moment!! My NSF door won't open from the outside!! It still loks with and without fob, it still opens from the inside. I'm going to try and have a look tomorrow..... But I would really appreciate and comments and advice that may help me find what to look for first! My 146 is due for MOT in 2 weeks, so need it fixed!!
Thanx for reading - hope someone can help!!
Cheeeeeeeerrrrrrzzzzzz
Hayley
Hi welcome
most likely to be one of the connector rods come loose, or the plastic connector that joins it all up has broken, easily done if the door has frozen up.
To look at it you need to remove the door card, which is a it if a fiddle. Pop off the plugs in the door handle and undo the bolts there, pop of the square-ish plug by the interior door handle to reveal another screw there, then most difficult of all, remove the speaker grille, the plastic tabs clip on, but getting them off in one piece needs care. There may be IIRC a couple of screws at the bottom of the door card, undo them, then pop the door card off the door with a spreader or large screwdriver, something that spreads the load, small and sharp will cause damage. Once the poppers are all undone lift the card upwards off the top channel.
You can now access the lock by peeling back the plastic cover and begin to see what the problem is.
IIRC there is a how to on the 145.com site, but you will need to register to see it
HTH
Mine do that when it's freezing weather but not sure why, I just pull the handle as soon as I hear the lock click. I have to be quick and it takes a couple of tries. It's fine most of the time ???
Not sure if yours is the same problem but good luck !
No.. yours sounds like a sticky Central Locking.
You need to take the door card off and dry out the electrical connector .. and then spray some water dispersant into it. The lock mechanism itself probably could do with some fresh grease too.
The OP's problem is not related.. they have a lock/handle issue..
Ralf S.
