1 - 20 of 21 Posts
:rant: OK I GIVE IN THE GARAGE GIVES IN THE POWER OF ALFA COMPELS ME!!!!! I HAVE A KNOCK THAT SOUNDS LIKE SOMETHING CAUGHT IN THE ALLOY..ITS NOT! ITS NOT THE DRIVE SHAFT AND ITS INTERMITTENT..IN TYPICAL ALFA STYLE IT STOPS WHEN IT SEES THE GARAGE!!! MAKES NO DIFFERENCE WHEN YOU ACCELERATE OR DECELERATE IT STILL KNOCKS TURNING CORNERS STILL THE SAME AND FULL LOCK NO DIFF.... WE ARE ALL CONFUSED ITS BEEN UP ON THE RAMPS FLASHING HER UNDERSIDES A DOZEN TIMES ..NOTHING IS LOOSE NOTHING IS SLACK NOTHING IS OBVIOUS..GRR THE FASTER YOU GO THE FASTER IT KNOCKS AND VICE VERSA AND IT STARTS OFF FAIRLY QUITE THEN REACHES A LOVELY CRESCENDO(NOT REALLY HOW I WANT TO TURN HEADS) THEN IT STOPS!!!! HELP ME PLEASE CLUES PLEASE..ALL CVS BALL JOINTS BOOTS ETC ARE FINE SUSPENSION SPOT ON AM I DRIVING A POLTERGEIST???:wow: :eek:
M
ah...the pleasure of driving italian...
on a serious note, could it be an engine mount
:D
does it do it if the engine is run without the aux belt?
alternator, a/c compressor, pas pump...
does it do it when stationary or just on the move?
engine vs drive train
does it do it whilst moving but the engine off?
drive train,
sounds daft but is it possible there is something inside a tyre?
Only Does It When On The Move Not A Sound When Stationary. Been Ramped Up Does It When Driven On The Ramps But Tyres Wheels Rock Solid Tyres 35s So Rubber Bands Not Likely Ought In There Lol....def Sounds Like Metal On Metal.......bloody Loud When At Its Peak Eek
A friend had something similar, it turned out to be a tyre de-laminating internally.
does it vary with rpm?
electro magnetic clutch on the a/c compressor would make a sort of "clack" if you know what I mean...
A
This could be coming from the wheel bearing. Just one of the balls starts to break up in one spot and makes the noise,then turns slightly in the race and the noise disappears. You won't feel any free play in the bearing.
Just a possibility.
It must be loud for you to be shouting in your post ;)
I'd swap the car for a few days with a courtesy from the garage and let one of the mechanics drive it for a while so that they can diagnose it properly.
Better that than rebuilding it from the tyres up (or getting an exorcism done... they never drive the same afterwards).
lol, glad you noticed even the stereo dont drown it....garage is doing the old bit scratch of the head thing they have had it when it knocks but nothing when up on ramps lol...its ok ive not spent anything yet bill will be 30p ( a 10p sun and a box of matches) the joy of alfa......btw no thanks to the courtesy car last time i got a giant tic ford kas just dont do it for me..just need to start a new trend....instead of the alfa wave we could have the alfa knock??? just a thought lol
Just a possibility.
I would second this theory since I had exactly the same symptoms and it was the wheel bearing.
hello fatty here have you sorted the problem out yet as mines doing the same thing had a price on wheel bearings £47 and about £30 to £50 to fit them before i order them i just wondered if these were the problem because the ni=oise is really getting on my **** now !!!!!!!!!:confused:
lol fatty not got it sorted yet going back in on monday to try the bearings only puzzle with that is no whine from wheel b4 it started??? i will kep you posted luckily my bro is a mechanic so my labour is free!!! he doesnt think its the bearing but picked up a drive shaft for £57 so going to change that too......failing that well do you want to join me in the burning ceremony lol:mad: :cry: :cheese: :lol:
I have the whining noise but that seems to come from the rear hard to tell only starts at abou 85 mph got car booked in now for wednesday morning and a service next monday then I sell it and am buying a maserati 4200
Hi, sorry to hear about your trouble. I too would be interested to know what the resolution is as I am getting scrapping and knocking noises when i turn my wheel so I am thinking my trouble could be a wheel bearing issue... mines not so loud that I can hear it above the music though. I use that to drown it out so i don't hear it in the hope that it goes away! :)
fatty here went to pick car up and they hadn't fitted the bearings could not find anything apart from slight whining noise from rear did not get charged anything and he will keep wheel bearings in for me for future use going to alfa specialist on monday see if he has any ideas GRRRRRR I hate niggely problems why can't it be something simple I feel better after that little rant
Discussion Starter #20
yeha yeha i got no knock o/s drive shaft was in a word shafted......wheel bearings were fine ....now i play the yes no game with drivers window and demister ......yes the window works no the demister doesnt an hour later no the window doesnt work but yes demister does lol ......never ends haha but i can cope with that ..
1 - 20 of 21 Posts
