Hi Everyone,
I'm a new member, just joined this morning, my main reason for joining is to get away from the scare mongering of the general public and get some seasoned advice, I hope you can help.
I will soon be looking at getting my first Alfa, looking at spending £4000 on either a 156 1.9 JTD 16v Multijet Turismo / Veloce in the saloon or sportwagon verson, or maybe a GT 1.9 JTD 16v.
What I really need to know is am I going to find a decent one for the money I'm wanting to spend and what should I be looking for?
Hope someone out there can help, looking forward to hearing the advice......
Welcome.. :)
If you rummage around the Technical (Model) lounges, you'll get an idea of what can go wrong... :) The 1.9 tractor engine can wear out its water pump.. but as far as I know, that's the only model-specific issue. :)
£4k sounds like plenty of moolah... so you should be okay to get a pretty pristine one, particularly the '56.
Good luck..!
And post a picture.. :thumbs:
Ralf S.
Mechanically both models are essentially the same, but as said the 156 will be cheaper, age for age, than a GT, so you can get a newer / lower mileage 156 for your money - although the facelift diesels are quite sought-after.
Aim for a car that has a good service history, particularly one that has recently had the cambelt / tensioners / water pump changed by a good independent...or maybe a dealer:lol:.
Don't be too over-concerned about mileage - they can do quite big mileages if serviced well. Front suspension can be a wear issue too, so if that's been replaced that's a plus point, too.
Inevitably if you look on this forum you'll see plenty of whinges about problems, but that's just the nature of forums - people don't post when everything's fine.
You should find a good car at that money - good luck!
Banned
I'd be spending that amount on a decent GT, but bear in mind the GT is less practical than the 156 if you have to carry 4 people regularly.
The GT is a brilliant practical Coupé with proper rear seats and a nice sized boot :)
The last GT I traded on for the Brera had 110k on the clock and she was running sweet as a nut, serviced by Alfatune.
Good luck :thumbs:
