I am trying to do the gear selector plate, but am unable to get the battery tray out......any help desperatly appreciated.
D
You need to get the fuse box from front of battery out then 4 bolts incl one to hold airfilter. looks like one bolt might be under the tray
how do you get the fuse box out? now it is f*cking raining!
There are little clips you need to push in then pull the relay holders up and 4 bolts to undo one is underneath which you cant see.
The fuse box seems to be attached to the tray, somehow even after the 10mm nut is loosened off. Any ideas?
