Hi My front fogs on my 98 gtv are not working i've checked the fuses also when you switch then on the light on the dash lights up so i presume it is the bulbs. How would i go about removing the light units to change the bulbs please Cheers
The reflective corners nearest the centre of the car prise off ( there's a small recess adjacent to the fog light to assist with this but be careful as it is easy to break the plastic at the recess ). It reveals three screws. Remove the two identical ones ( the third one with the plastic collar adjusts the foglight aim ). You then wiggle that corner out whilst moving the unit towards the centre of the car to release the peg at the outer end.
