1 - 10 of 10 Posts
this is terible my 155 q4 is stopping when i am driving. the engine cuttof suddenly and it is imposible tu get started:mad:
but after an hour or 3 it starts like nothing is wrong.
it seams like the engine stoppes when i have driwen 20min or so. :confused:
the rpm arow drop down when the engine is stopping but still in 4th gear so it is spinning at 2500rpm but it dosent show.. :confused:
some say that it is the ignition module, is this ekspensiv :confused:
Definately sounds like a temperature related problem.................might be temp sensor or crank sensor or cam sensor or anything breaking down once its got hot :rolleyes:
Have you had it on a diagnostic yet :confused:
I would try and get it to a dealer/specialist and rigged to a diagnostics as Speedy says, it will save a lot of time and hassel as in theory the problem should pop up straight away :D
Im going to be different and say its the lambda causing fuel starvation when hot! :eek:
no i havent had a diagnostic yet but i will if i find a workshop that have the right diagnostic system..
but if the engine is running can they find the error then???
or due they have a portable diagnostic thing??
Do you get the code light come up when the engine dies? if so the error may be stored for the diagnostics to fish out, but im not sure if the Q4s had this system like twinsparks etc
Wouldnt have thought the diagnostics thing would be portable but someone else would know better! :)
Good luck with it and let us know how you get on
Jack
Discussion Starter · #6 ·
Jack
i dont think i got the code light system. i didnt se anny xtra lights:(
i will innform you when i find the error:)
Jørgen
Discussion Starter · #8 ·
Had a similar problem on a previous car (Rover).
Turned out to be the crank position sensor failing when it got warm.
Robert
Something sill to try is if the fuel tank breather is blocked. When the engine cuts out open the fuel filler release pressure. If the engine restarts then you've got the problem. If not then all of the above.
Phil
Discussion Starter · #10 ·
crankshaft (TDC) sensor, located on the front pully it will have either a white or black lead on it.
1 - 10 of 10 Posts
