Goood Afternoon,
Sorry to bother you but I've got a problem on my 33 SIII. I changed my starter and after dodging all the hoses I noticed some coolant on the floor of the garage.
I've checked the entire circuit and there is no leak anywhere however I managed to locate the problem. The Driver's Side Drain Plug is the culprit, its dropping a drop every 2-3 hours but none when running.
Now I am worried as I need to replace the coolant but don't remember in which direction to loosen the nut when working from infront of the car and not behind it, also I don't want to snap it in the process.
Any ideas what could have happened, did it ever occur to anyone? What do I do use PTFE a New washer ? Never seen like it.
Appreciate the Help
Regards,
Keith
Appreciate the Help
Regards,
Keith
