any ideas, was perfect before but i always like to clean throttle bodies. now idle is horrible should i disconnect battery? its a selespeed so makes driving awful in first
i know not the wonders of selespeed.
if it was a TS i would say
1. maybe too much cleaner got into the engine, let it settle
2. check the TB is adjusted ok, you may have knocked it off
3. do a throttle reset
4. if not above, you broke it
how do you do a reset? i am an engineer so capable, i only cleaned around the butterfly gently with brake cleaner and rag so didnt knock anything for sure - didnt remove body so gasket is fine
again, i can only go by what a TS does.
some types of TB are easily damaged (non throttle cable types) not sure if seles are like this or not.
a throttle reset for a throttle cabled TS is as follows.
ignition key to MAR for 90 secs
back to off for 90 secs
start up, and let idle for 15 mins (dont touch throttle)
turn off
go for a spin - vary driving styles
may take a day or two to fully settle
