1 - 11 of 11 Posts
It started with the car making a noise like the air con system was playing up. Took to dealers who said they couldn't find a problem. 1 month later and warrenty run out engine managment light keeps coming on and car goes into safe mode with dramatic loss of power. Alfa has said the codes are p2313, p2013, p111 and have produced a list of parts as long as your arm. They have said £1100 in parts and £900 to fit. But they can't/won't explain the problem.
Can any one explain the codes and give some advise as alfa won't due to warrenty expired.
Need some help please!!!
Ps on a positive note the noise has nearly stoped.
p2013 - Intake manifold air control actuator, bank 2 circuit high, - wiring can be short to positive or maybe actuator needs a little bit of cleaning.
p2313 - again check wiring and coil E
p111 - check air intake temperature sensor (IAT)
Hope this helps...
thank you!! really helpfull. gonna speak to simply alfa tomorrow who think they can help now i have given them your information.
Stress!!
thanks again for your help. the dealership wanted to change a list of parts as long as your arm and charge me 2k for parts and labour.
Getting P0016? Help!
i've a brera 2.2 from 2006. for the last 10 months i'm getting the engine light always on and everytime i start the car i also get the engine warning.
I´m from Portugal and i´'ve been in almost all alfa romeo mechanics and nobody gives me the solution,. they all erase the error, reset the system and try to charge but it just lasts a couple of hours.
The error is the P0016?anyone knows how to solve the *****??
help me guys
thnks alfistas
I've been told that on your model the chain gets stretched so might need to replace it. Simplyalfa have fixed my problem now. Dealers wanted £2100 simplyalfas done for £793.
I have been suffering a recurring P2013 error, The local dealer cleaned a valve, charged me £145, and the problem went away.....briefly
From what I have read on the forum, the solution seemd to be a replacement of the inlet manifold. Have I understood this correctly.
I was wondering if anyone could give me an idea of prices for having this work done. As the car is now out of warranty, I am loathed to pay dealer prices.
I changed manifold gaskits & cam belt and they cleaned out e..? Value £793 car drives fine again now. Speak to simplyalfas. They were the cheapest I could fine & they do no what there talking about. If you give them a call there more than happy to have a chat about it.
Hi, I am from Peru, I read in this post about P0016 error and how solve it. I got an 159 2.2 from 2007 with the same problem. Following the Alfa dealer instructions We changed the 2 electro valves in the engine but light engine keep on, I asked them about check timing chain but it did not solve the problem. I know the dealer have the same problem with a Brera 2.2 too, can you help me?
1 - 11 of 11 Posts
