1 - 13 of 13 Posts
Hello I have a 56 plate 2007 156 Selespeed. The gearbox will go from 1st to 2nd gear also go in reverse, But will not change up to 3rd 4th and 5th, The car has only 22000 miles from new so i cannot imagaine its anything major, I notice the intiial drive off is very jolty.
If any help me out here in based near Norwich
Best Regards
Brett
L
if the engine is stopped but the key is at MAR can you select more than 1 2 & R?
can you hear the pump running duirng gear changes?
does the Selespeed symbol in the Rev counter flash ?
Discussion Starter #3 (Edited)
Hi Mate
Thanks for the reply. I have not tried gear selection in MAR. I will try this tomorrow.
The Selespeed symbol does not come on and i can hear the pump working when selecting 1st and 2nd etc
I notice that the transmission fluid is on the min mark though
Thanks for your help
L
with the engine started it will only select 1 2 & R unless its actually driving. with the key at MAR & engine stopped it should select all 5 fwd & 1 rev gear.
Hello
Right i have done as you said.
Put the key position into MAR and still only 1st and 2nd gears no 3rd and above,
There are no warning lights on the dash
The car very jolty wgen trying to move forward.
We plugged the car to the diagnostics machine it said there was no signal from excelerator position sensor
Code number p1770 and p763
So i assuming i am limp mode?
Brett
L
p1770 - accelerator pedal absent.
I suspect you have an issue with one of the 3 sensors for the selespeed system
Right so you think it could be expensive job?
Strange enough i have not many cars as late as mine, Its a 56 plate Registered Jan 2007
Can anyone recommend anyone to in the Norfolk area?
1 - 13 of 13 Posts
