1 - 20 of 24 Posts
Hi all
i nned help in deciding what to do next ,My 147 jtdm was doing ok untill today it had been quite stiff in getting into gear for a while and just seamed to be getting stiffer then my wife went out today she got two roads away then could not get it in gear at all ,any ideas as where i should go next or what should i try :cry:
Thanks Pete
think you need it checking out by a specialist what part of country are you?
was bite point changing when wifey was driving it earlier
L
dip the box for oil, dipstick at the rear of the gear box, back under the battery
harefield near watford used proalfa before they have replaced a clutch slave cylinder for me on 8/02/2011 ,As for bite point changing while wifey was driving there was no change , Just checked gearbox for oil level to the max and clear
Agreed with davealfa, try bleeding, or suspect your master cylinder, plenty of comments on here about one going after the other's been replaced
i actually work for a garage parts sales ,And think it is a blown pressure plate ,So if its a case of clutch will they want to do the flywheel as well
flywheel is part of the clutch process . its not just a lump of metal its a huge damper to put it lightly and if that has failed new clutch as well
1 - 20 of 24 Posts
