Morning all.
New to this forum as I`m trying to help a neighbour who`s P reg Spider has suffered bottom end failure.
It`s a 1970cc twinspark model. Basic question is this - will the short block from a P reg 1970cc 146ti fit?
Thanks in advance.
many thanks.
Is the 146 engine a 16v? Can I swap the whole lot and maybe just change the ignition system? Anything else that needs swapping so that the Spider ECU will fire it up ok?
Everything is the same on the engine, although watch the gear ratio's. There are also 2 types of ECU fitted to the aluminium cam cover version of the TS engine. Make sure you get the right one.
