Hi all,
Recently, the airbag light turned on for no apparent reason on my 04' 2.0 156 selespeed. My best guess is that the connectors got knocked loose as I was adjusting my seat.
So I followed a tutorial on another thread on how to get rid of the light but it's just not happening for me :/ I have tried disconnectiing the connectors under the seat and spraying it with wd-40 and connecting them again but had no luck.
I've got the KKL connector and the red airbag ECU adaptor hooked up to the car and it's able to connect but a red flashing light (Latency too high) comes up on my laptop screen as soon as it does. Also the 156 Selespeed has ALLIED airbags on Multiecuscan however software tells me that my car has SIEMENS so I had to connect to the 2.0 TS 16V module.
The fault is read and I hit clear faults but nothings happens.
Any suggestions on how to turn the light off would be greatly appreciated!
A side note that I'm not game to try disconnecting the battery for 30min and connecting the leads again because I don't have the key codes on me
