1 - 14 of 14 Posts
Sorry if this is the wrong section but I'm in a bit of a jam!
I left the rear hub from my 156 into a local garage to get the stub axle bush pressed out and a new one pressed in and they made a complete arse of it. They have bent and smashed the ABS trigger ring and basically said F U, not our problem. Car is due for NCT tomorrow and I can't find a scrapper that is open near me.
if someone is breaking one or knows where I can get one I would gladly give a kidney, has to be today though!
my number is 0-8-7-2-0-2-5-1-8-5 fire me off a text and I'll call you back.
if anyone would like to know which garage it is PM me and I will gladly oblige.
You're grand Peader, once they get put to good use. I have the old one boshed for now. Stuck the trigger ring back together with superglue and seems to be holding for now so im good to go for nct, woo!
Discussion Starter · #6 ·
Not gonna happen Dave, you know the front wheel bearing the garage pressed in for me? It's fooked, wheel is wobbling round worse than with the old one.
I said to him It felt a bit notchy when I picked it up and the trigger ring on THAT bearing was kind of pushed out aswell. All I think of is he didn't use the press he has and just welled the thing in. Fooking amateur!!!
So no point going up for the test as the wheel bearing wil not be a visual, words cannot describe how angry I am with this absolute d1ckhead. I spent the whole day putting it all back together yesterday (and 2 hours trying to find a new rear hub, and then another hour patching the one he ballsed up back together) torqued everything up properly only for this to happen.
Out of three things I gave him to do he destroyed two of them:eek::eek: he did mention he has been quiet lately, I guess I know why now.
I have been known to have a bit of a short fuse in the past, its somthing I have had to work very hard to restrain but I think, given the circumstances this chap will be getting the full wrath when he opens on Monday.
Christ Jim, sorry to hear your having all this trouble. Is it too late to rebook the NCT to another date? Good luck getting it sorted
Discussion Starter · #9 ·
When I tried to rebook I had to do it by first registration date, and the date I was putting in was the wrong date and after a few goes it locked me out, tried to call but they are closed weekends. Not sure what they'll charge me now!
Jesus I thought I was having a rough time of it....
Hope it levels out for you soon Jim.
What ails your fleet Frank? 33 is back and firing isn't it? The end is in sight now I think, I have the hub carrier back off again ready to beat the garage man with on Monday, so after he has healed and redone the bearing it should be sweet for the test. On the plus side I got it stripped off in 25minutes now I'm getting so well practised:lol:
Discussion Starter · #10 ·
That's pretty crappy.... did you get sorted now ? There is a scrappy near by with 2 156's if you're stuck for a rear hub... I can ask if you want?
Discussion Starter · #13 ·
Hello there Stranger! How's it going Cathal? I managed to track one down in Ratoath not far from me was at it tonight but the lower bolt that holds the transverse arms is SEIZED so I'm going back for another crack at it tomorrow with a blowtorch and angle grinder if necessary!
Nothing at the moment but Ive had more than my fair share in the past!
Are you still roaming the streets or have you been caught for GBH? :lol:
They haven't found the body yet Frank so should be good for a while:lol: front is now sorted and back together but the back hub ABS is acting up now so I guess my superglue fix has let go.
Hey Jim.. all good thanks.. Lots of heat will fix anything! ;)
Hope it's going a bit better now...
Talk soon,
Cathal
1 - 14 of 14 Posts
