first I would like to thank anyone who recently gave advice on my gear probs .was very useful and now gears are changing fine .
no sooner did i have it fixed when ,driving back from the garage the car just suddenly stops . True, the fuel light is on but Ah think there is still enough in tank .battery did not take long to drain . In the event of fuel starvation is there any way Ah can get fuel into the system ?
i would make sure fuel is topped up first,turn key to mar then off and then to mar then crank engine over ,should start,if not prob crank sensor
cheers for the info lads ( great wee thing this forum) .Did as you`s suggested . Got the temperamental pest goin . Seems that it could be the sensor that you both mentioned . Where is it ? is it accessible ? One thing of note ; my control system warning light had come on when Ah got the car goin . Bearing in mind that you `s said it could be a sensor , Ah stopped ,turned off ign , lifted the bonnet and shook the engine . when Ah started her up again ........ the warning light was gone !! woohoo ah said after "thank f***".
ps meant to say . checked some other forums regarding crank sensor .Seems that it can start goin mental wen it heats up . Quite like ma other lovely pest . .her name is audrey and a human ........ sometimes
It's in the engine block, under the starter motor. Held in by one allen key bolt, and it's the brown connector under the engine cover.
Got a few spare if you want one, but they're only about £20 new.
