10 degrees?So if I want the temp to be 10 degrees - how do I do it?
It is physically impossible to get hot air from recently started cold engine.:thumbup:
I take it the answer is 'no control' then!
Just fed up of being blasted with unpleasant hot air every morning as the uber climate control tries to get the temp up to 16 degrees. Opening the windows a bit only lowers the temp so the system blows even harder and hotter to compensate.
"Upto" 16 degrees? Are you made of molten lava? My server room at work runs at 17C and I bung a coat on if I'm in there for more than 5 minutes, why on earth do you want to be down at 10C?:thumbup:
so the 'lo' option isnt cold enough?:thumbup:
