check your coolant level in the expansion tank,under the bonnet drivers side,if all was well previously,and it has dropped suddenly,you need to investigate further,as you may have a leak etc which will need sorting or you will cook the engine,good luck.
what about engine coolant temperature,is it at 90 or stays below all the time,if thermostat has broken down fan wont blow hot air obviously :)
