1 - 2 of 2 Posts
I have a 2011 giulietta 17.50 cloverleaf only seem to be getting slightly warm air from heater but only on passenger side drivers side cold have read that a possible internal temp sensor in mirror is ths easy to change ,also wondering if could be flap motor though i can hear movement when i change settings any ideas cheers vaughan
The sensor in the mirror is, I believe, in the door mirror and gives the external temperature.
With climate control you can have different temperatures for passenger and driver so presumably two internal sensors.
There are a number of threads on here about heater problems so a good place to start would be with a search.
With the new layout search seemed to have disappeared but if you click on the three dots top right of the banner then the drop down includes a search option
1 - 2 of 2 Posts
