Can anyone help? The drivers side headlight washers on my 159 have decided to stop working. The passenger side and the window washers are still working fine. Is there an easy way to checking the hoses, or is it a trip to the dealer?
Thanks in advance
Banned
I am sure dedicated tube lost from distributor.
Front left wheel to be jacked up.
Wheel, inner lining, washer tank to be taken off.
You will see it.
You will see it.
This would be for LHD, for RHD the Air Filter assembly will be in your way.
You might be able to reach the hose with the engine base cover off.
Probably the splitter non return valve rusted out, I gutted mine and it's been fine, just have a few tears from the washers everyone and then. Just whip the undertray off and have a look.
I'm local ish if you need a hand.
Thanks R159. I will get her up onto some stands and have a look. If I need any help, i'll give you a shout:thumbs:
