hi, silly question, just brought a 1992 155 ts 2.0 model, there was no hand book with the car so am learning as i go! can you tell how you get the headlight washers to work as i can`t, the window washers work fine but can`t get the headlight ones tom work or even find how you make them work as in button!!!
thanks
martin
The headlight washers work automatically if your lights are on, side or main beam and you use the windcreen wash button.
Simon.
Someone may have pulled the fuse to switch them off. I did on my 155. I found them to be useful for emptying the bottle and hopeless at clearing the lights.
There should be a fuse somewhere, probably on an auxiliary bracket. It will be a yellow 20A. My car was 2.0 16v so it had a different fuse box to yours.
As above...fuse, put lights on or perhaps the motor is burnt out or gunged up. Also have you checked to see if there's a big puddle under the car, the water lines are known for cracking/breaking inside the bumper.
Is the motor spinning is the first question ;)
wrinx
