Hi , I appear to be getting some faults on the electrics on my 2012 Giulietta. I have sorted the tailgate opening button by repairing a broken wire in the l/h side gaitor. I now have a main beam headlight not working on the nearside. Lamp (bulb) is o.k and there`s 12volts at the connection - but this drops to zero when connected (yellow cable).Earth wire (brown) is earthing. Has anyone had this problem. Thanks for any help. Regards, Richard.
Hi thanks for the information - that sounds an expensive fix.is it possible to have it `reset` or perhaps connect the non working light to the other working one.
Will need to be a dealer fix as body computer will need programmed once fitted. Computer would probably shut down if you ran a wire over to the other light as it would sense an increase in the load.
Thanks for information - I bought it from Research group at Nuneaton,who have serviced it for the last 3 years,I`ll give them a call. I will update when it`s sorted. Thanks again.
