1 - 9 of 9 Posts
I've just switched to Osram Nightbreakers for my dipped beam and they're not bad either. The standard bulbs on the 147 are junk... not only that, the headlights are aimed a bit too low.
I don't know about the 156, it's a nightmare to swap out the H7 bulbs on the 147. The dipped beam bulbs are almost inside the wing and you have to be a contortionist to get your hand inside.
I have a facelift 156 and changing the bulbs are a piece of ****, minute or two each side. Dunno about the pre-facelift.
i've got the phillips - much better than the standards, bugger to change tho. i'm missing a few bits of skin after doing mine :)
Now I've had a chance to check them it's the right hand side-light, so the dipped beam is fine, and as far as I know, the full beam is fine too (I didn't check!). I think that means it's not as urgent and that I can wait until the service, but should I upgrade my lights?
1 - 9 of 9 Posts
