I had noticed a while back that the leading edges of the rear wheelarches just after the rear door shutline (if that makes sense) have started taking on a shotblasted effect; i.e. the paint is starting to become very rough as it has a lot of very fine chips down the edge.
The dealer have raised it as a warranty issue but it's not something that can be properly sorted as even if it is painted it will happen again. The rear door is flush at the top and bottom just that it sits in along the middle section leaving the wheelarch sitting slightly proud and exposed to the elements.
Anyone else had this problem?
