· Registered
hi All,
just wondering if anyone out there has ever fitted an aftermarket keyless entry system instead of paying the stealer mega bucks for a new remote key?
if so what success have you had?
which systems did you use?
i am looking to fit such a system and unsure of the wiring, I know the system is a Negative driven system but that is about it as i havent got a wiring diagram for the vehicle
all responses welcome
cheers
· Registered
I've not done this myself, but the information i have is
facelift=
Connector: WHITE 18 way attached to
the ABI control unit fitted behind the
passenger´s side glove compartment.
Position: NR 16 and NR 15.
negative.
UNLOCK:
WHITE-BLACK 0,75 mm2.
LOCK:
LIGHT BLUE 0,75 mm2.
Pre Facelift
Position: NR 5 and NR 4
The wire colours are listed as gray and yellow, but its not listed which is lock or unlock
HTH
· Registered
facelift=
negative.
UNLOCK:
LOCK:
Pre Facelift
HTH
This info is very useful, it saves a load of nmessing about. I have done this conversion on a couple of cars but not an Alfa and thy have always worked well.
